Ana içeriğe geç
Dell XPS 18 Battery Replacement
Neye ihtiyacın var
    1. Dell XPS 18 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
      • Turn the device on its screen.
      • Remove the ten 4mm screws using a T8 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 18 Battery Replacement: adım 2, 1 resimden 1.
      • Gently flip out support feet located near the bottom of device.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS 18 Battery Replacement: adım 3, 1 resimden 1.
      • Gently lift the back cover off the device. The back cover should come off easily.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS 18 Battery Replacement, Internal Cover: adım 4, 1 resimden 1.
      • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 18 Battery Replacement: adım 5, 2 resimden 1. Dell XPS 18 Battery Replacement: adım 5, 2 resimden 2.
      • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS 18 Battery Replacement: adım 6, 2 resimden 1. Dell XPS 18 Battery Replacement: adım 6, 2 resimden 2.
      • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
      • Remove the internal cover.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS 18 Battery Replacement, Touch Control Board: adım 7, 2 resimden 1. Dell XPS 18 Battery Replacement, Touch Control Board: adım 7, 2 resimden 2.
      • Disconnect the black camera cable and pull it back to prevent future hassle.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 18 Battery Replacement: adım 8, 2 resimden 1. Dell XPS 18 Battery Replacement: adım 8, 2 resimden 2.
      • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
      • Disconnect the silver and blue touch control board cable.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS 18 Battery Replacement: adım 9, 2 resimden 1. Dell XPS 18 Battery Replacement: adım 9, 2 resimden 2.
      • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
      • Remove the touch control board.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS 18 Battery Replacement, Wireless WLAN Card Wires: adım 10, 1 resimden 1.
      • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 18 Battery Replacement: adım 11, 2 resimden 1. Dell XPS 18 Battery Replacement: adım 11, 2 resimden 2.
      • Pull back the cables.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS 18 Battery Replacement, Battery: adım 12, 1 resimden 1.
      • Use the plastic opening tool's angled edge to pry the black battery cable loose.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS 18 Battery Replacement: adım 13, 1 resimden 1.
      • Use the plastic opening tool's angled edge to remove the red and black CMOS battery cable.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS 18 Battery Replacement: adım 14, 2 resimden 1. Dell XPS 18 Battery Replacement: adım 14, 2 resimden 2.
      • Use the plastic opening tool's angled edge to lift the clasp securing the silver circuit board cable.
      • Pull back the circuit board cable to prevent future hassle.
      FixBot'a Sor
      Yorum Ekle
    4. Dell XPS 18 Battery Replacement: adım 15, 1 resimden 1.
      • Use the opening tool's angled edge to remove the CMOS battery.
      • The CMOS battery is adhered with strong adhesive; you may need to use extra force when removing.
      FixBot'a Sor
      Yorum Ekle
    5. Dell XPS 18 Battery Replacement: adım 16, 1 resimden 1.
      • Remove the eleven black 4mm screws holding the battery in place with a Phillips 00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. Dell XPS 18 Battery Replacement: adım 17, 1 resimden 1.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Austin Weir
1.308 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G29
4 Üyeler
16 adet Kılavuz yazıldı
9Kılavuz Yorumları
needs the help to repair the Dell XPS18
anrew waleta - Yanıt Paylaş
This is an excellent doc! Pictures are really clear and accurate, steps are concise and best of all they are correct. I was able to solve my issue the first go round with these instructions. Kudos to the author and thanks a million for the assistance!
stacysaw - Yanıt Paylaş
It all worked good. Thanks.
Kenneth Macdonald - Yanıt Paylaş
Excellent!
What is the battery type and where to buy, thanks
Mohammad - Yanıt Paylaş
My unit is missing the right foot stand. Is there anywhere else I can find the model number. Need to purchase a new power supply?
Also might need to replace the touchscreen its cracked. Have to power her up first to find out. Do you have a video for touchscreen replacement?
Frank Schofield - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 23
Son 30 gün: 59
Her zaman: 17,074
