Ana içeriğe geç
Dell XPS 18 Left and Right Speakers Replacement
  1. Dell XPS 18 Left and Right Speakers Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Left and Right Speakers Replacement: adım 2, 1 resimden 1.
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Left and Right Speakers Replacement: adım 3, 1 resimden 1.
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: adım 4, 2 resimden 1. Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: adım 4, 2 resimden 2.
    • Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
    • Disconnect the volume control cable and pull it back.
  5. Dell XPS 18 Left and Right Speakers Replacement: adım 5, 1 resimden 1.
    • Firmly pull the blue speaker cable loose.
  6. Dell XPS 18 Left and Right Speakers Replacement: adım 6, 1 resimden 1.
    • Remove the two black 4mm screws with a Phillips 00 screwdriver.
  7. Dell XPS 18 Left and Right Speakers Replacement: adım 7, 1 resimden 1.
    • Carefully remove the speaker.
    • To remove the right speaker, follow these same steps.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Weir
1.263 İtibar
8 adet Kılavuz yazıldı
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G29
4 Üyeler
16 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 1,032
