Ana içeriğe geç
Dell XPS 18 Wireless WLAN Card Replacement
Neye ihtiyacın var
  1. Dell XPS 18 Wireless WLAN Card Replacement, Back Cover: adım 1, 1 resimden 1.
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Wireless WLAN Card Replacement: adım 2, 1 resimden 1.
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Wireless WLAN Card Replacement: adım 3, 1 resimden 1.
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Wireless WLAN Card Replacement, Internal Cover: adım 4, 1 resimden 1.
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Wireless WLAN Card Replacement: adım 5, 2 resimden 1. Dell XPS 18 Wireless WLAN Card Replacement: adım 5, 2 resimden 2.
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Wireless WLAN Card Replacement: adım 6, 2 resimden 1. Dell XPS 18 Wireless WLAN Card Replacement: adım 6, 2 resimden 2.
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Wireless WLAN Card Replacement, Touch Control Board: adım 7, 2 resimden 1. Dell XPS 18 Wireless WLAN Card Replacement, Touch Control Board: adım 7, 2 resimden 2.
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Wireless WLAN Card Replacement: adım 8, 2 resimden 1. Dell XPS 18 Wireless WLAN Card Replacement: adım 8, 2 resimden 2.
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Wireless WLAN Card Replacement: adım 9, 2 resimden 1. Dell XPS 18 Wireless WLAN Card Replacement: adım 9, 2 resimden 2.
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Wireless WLAN Card Replacement, Wireless WLAN Card Wires: adım 10, 1 resimden 1.
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  11. Dell XPS 18 Wireless WLAN Card Replacement: adım 11, 2 resimden 1. Dell XPS 18 Wireless WLAN Card Replacement: adım 11, 2 resimden 2.
    • Pull back the cables.
  12. Dell XPS 18 Wireless WLAN Card Replacement, Wireless WLAN Card: adım 12, 1 resimden 1.
    • Remove the two silver 3mm screws with a Phillips 00 screwdriver.
  13. Dell XPS 18 Wireless WLAN Card Replacement: adım 13, 2 resimden 1. Dell XPS 18 Wireless WLAN Card Replacement: adım 13, 2 resimden 2.
    • Angle the wireless WLAN card upward and remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Austin Weir
1.287 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G29
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,308
