Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
The card fan is located at the bottom left corner of the computer.
Remove the cable connecting the fan to the motherboard.
Disconnect the fan from the cage housing by pressing down on the release triggers and pushing them to the right.
Slide each corner of the fan cage off of the rubber grommets attached to the fan.
3 farklı kişi bu kılavuzu tamamladı.
