Ana içeriğe geç
Dell XPS 720 H2C Hard Drive Replacement
Neye ihtiyacın var
  1. Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: adım 1, 2 resimden 1. Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: adım 1, 2 resimden 2.
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  2. Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: adım 2, 2 resimden 1. Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: adım 2, 2 resimden 2.
    • The hard drive is located the top-center area of the computer.
    • Carefully disconnect the data and power cables from the hard drive.
  3. Dell XPS 720 H2C Hard Drive Replacement: adım 3, 1 resimden 1.
    • Push the tabs on both sides of the hard drive bracket towards each other and slide the hard drive up and out of the hard drive bay.
  4. Dell XPS 720 H2C Hard Drive Replacement: adım 4, 2 resimden 1. Dell XPS 720 H2C Hard Drive Replacement: adım 4, 2 resimden 2.
    • Unscrew the four 5mm screws on both sides of the hard drive using the Phillips #1 screwdriver and then remove the hard drive from the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
G B
67 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,767
