Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
The hard drive is located the top-center area of the computer.
Carefully disconnect the data and power cables from the hard drive.
Push the tabs on both sides of the hard drive bracket towards each other and slide the hard drive up and out of the hard drive bay.
Unscrew the four 5mm screws on both sides of the hard drive using the Phillips #1 screwdriver and then remove the hard drive from the case.
2 farklı kişi bu kılavuzu tamamladı.
