Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
Before handling the inside of the computer, ensure that all wires are disconnected from the audio ports along the back panel.
The sound card is located towards the bottom of the computer, near the righthand side (see red outline).
To remove the support below the processor: press down on the latch at the top of the support, then pull the support outwards, towards yourself.
To unplug the wire that connects the sound card to the motherboard: grasp the wire tightly and pull it outwards, towards yourself.
To release the sound card from the motherboard casing: find the blue tab that is the third from the bottom (fifth from the top), and press down and to the right on the tab.
To remove the sound card from the motherboard: gently grasp the sound card and pull directly outward, towards yourself.
Bir başkası bu kılavuzu tamamladı.
