Ana içeriğe geç
Dell XPS M1210 RAM Replacement
Neye ihtiyacın var
  1. Dell XPS M1210 RAM Replacement, RAM: adım 1, 3 resimden 1. Dell XPS M1210 RAM Replacement, RAM: adım 1, 3 resimden 2. Dell XPS M1210 RAM Replacement, RAM: adım 1, 3 resimden 3.
    • Steps for Bottom-Side Memory Slot
    • Turn off the computer, unplug the power adapter. Remove the battery, after sliding the battery latch, until you hear a click.
    • Remove 1 star screw, so you can remove memory cover. Using your fingertips, spread apart the clips, which secure the memory module in place.
  2. Dell XPS M1210 RAM Replacement: adım 2, 3 resimden 1. Dell XPS M1210 RAM Replacement: adım 2, 3 resimden 2. Dell XPS M1210 RAM Replacement: adım 2, 3 resimden 3.
    • Once unsecured, the memory module will pop up, so you can remove it at a 45-degree angle.
    • When installing the new memory module, you will notice it can only be inserted in one direction, due to the memory module indents.
    • Secure the module with the clips, click it into place, and reinstall the memory module cover in reverse order of the above instructions.
  3. Dell XPS M1210 RAM Replacement: adım 3, 2 resimden 1. Dell XPS M1210 RAM Replacement: adım 3, 2 resimden 2.
    • Steps for Top-Side Memory Slot
    • Remove the battery, after sliding the battery latch, until you hear a click.
  4. Dell XPS M1210 RAM Replacement: adım 4, 3 resimden 1. Dell XPS M1210 RAM Replacement: adım 4, 3 resimden 2. Dell XPS M1210 RAM Replacement: adım 4, 3 resimden 3.
    • With the laptop screen tilted 180-degrees, you can begin removing the rear hinge panel. The cover is not attached to any wires and covers the screws which secure the keyboard in place.
    • With the flat-head screwdriver or a thin object, pry up the hinge panel.
  5. Dell XPS M1210 RAM Replacement: adım 5, 3 resimden 1. Dell XPS M1210 RAM Replacement: adım 5, 3 resimden 2. Dell XPS M1210 RAM Replacement: adım 5, 3 resimden 3.
    • Remove the 3 Phillips-head screws at the top of the keyboard.
    • After the 3 screws are removed, you will be able to lift the keyboard, exposing the top-side memory module slot.
    • The keyboard will still be connected to the computer, via a ribbon cable. The ribbon cable is long enough to place the keyboard out of the way ...disconnecting the ribbon cable is not necessary.
  6. Dell XPS M1210 RAM Replacement: adım 6, 2 resimden 1. Dell XPS M1210 RAM Replacement: adım 6, 2 resimden 2.
    • Using your fingertips, spread apart the clips, which secure the memory module in place.
    • Secure the module with the clips, click it into place, and re-install the keyboard and hinge panel in reverse order of the above instructions.
Sonuç
To reassemble your device, secure the module with the clips, click it into place, and reinstall the keyboard and hinge cover in reverse order of the above instructions.
7 farklı kişi bu kılavuzu tamamladı.
Dave
229 İtibar
2 adet Kılavuz yazıldı
Ekip
Penn State, Team 1-100, Kaschak Winter 2015 Penn State, Team 1-100, Kaschak Winter 2015 üyesi
PSU-KASCHAK-W15S1G100
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 2,246
