Ana içeriğe geç
Dell XPS M1330 CPU Replacement
Neye ihtiyacın var
  1. Dell XPS M1330 CPU Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 CPU Replacement: adım 2, 1 resimden 1.
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 CPU Replacement: adım 3, 2 resimden 1. Dell XPS M1330 CPU Replacement: adım 3, 2 resimden 2.
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 CPU Replacement, Fan: adım 4, 2 resimden 1. Dell XPS M1330 CPU Replacement, Fan: adım 4, 2 resimden 2.
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  5. Dell XPS M1330 CPU Replacement: adım 5, 1 resimden 1.
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  6. Dell XPS M1330 CPU Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  7. Dell XPS M1330 CPU Replacement: adım 7, 1 resimden 1.
    • Gently remove the fan and its attachments from the bay.
  8. Dell XPS M1330 CPU Replacement, CPU: adım 8, 1 resimden 1.
    • Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
  9. Dell XPS M1330 CPU Replacement: adım 9, 1 resimden 1.
    • Using the iFixit opening tool, prop up the CPU.
  10. Dell XPS M1330 CPU Replacement: adım 10, 1 resimden 1.
    • Carefully lift the CPU away from its housing.
Sonuç
Kai Kapossy
676 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G2, Peak Spring 2019 UMass Dartmouth, Team S6-G2, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G2
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 896
