Ana içeriğe geç
Dell XPS M1330 Fan Replacement
Neye ihtiyacın var
    1. Dell XPS M1330 Fan Replacement, Battery: adım 1, 1 resimden 1.
      • Flip the laptop on its back, so that the underside is facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS M1330 Fan Replacement: adım 2, 1 resimden 1.
      • Push and hold the slide button to the left and unlock the mechanism.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS M1330 Fan Replacement: adım 3, 2 resimden 1. Dell XPS M1330 Fan Replacement: adım 3, 2 resimden 2.
      • Lift the computer up and slowly pull the battery straight out from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS M1330 Fan Replacement, Fan: adım 4, 2 resimden 1. Dell XPS M1330 Fan Replacement, Fan: adım 4, 2 resimden 2.
      • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
      • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
      • Remove the fan cover.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS M1330 Fan Replacement: adım 5, 1 resimden 1.
      • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
      • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS M1330 Fan Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Be sure to carefully remove the wires as they are fragile and can rip easily.
      • Remove the wire bay near the fan.
      • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
      • Gently pull upward while moving your hand side to side so the plastic holder will detach.
      FixBot'a Sor
      Yorum Ekle
    4. Dell XPS M1330 Fan Replacement: adım 7, 1 resimden 1.
      • Gently remove the fan and its attachments from the bay.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kai Kapossy
739 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G2, Peak Spring 2019 UMass Dartmouth, Team S6-G2, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 666
