Giriş
If your keyboard is unresponsive due to interior damage from liquids or dirt, or has been physically damaged, then use this guide to replace it. You will need a Phillips head #01 Screwdriver, a Flathead 3.0 Screwdriver, an iFixit opening tool, and tweezers. This process is a little more difficult than the previous, but you will have no problems in using this guide.
Neye ihtiyacın var
Remove the four 5.0mm screws with a Phillips #1 screwdriver.
Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
Remove the fan cover.
Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
Unscrew the 5.0mm Phillips #1 screw from the wireless door cover.
Pull straight up on the wireless door.
