Ana içeriğe geç
Dell XPS M140 Hard Drive Disk (HDD) Replacement
Neye ihtiyacın var
  1. Dell XPS M140 Hard Drive Disk (HDD) Replacement, Battery: adım 1, 1 resimden 1.
    • The first step is to turn over the laptop
  2. Dell XPS M140 Hard Drive Disk (HDD) Replacement: adım 2, 1 resimden 1.
    • Locate the slide lock for the battery.
  3. Dell XPS M140 Hard Drive Disk (HDD) Replacement: adım 3, 2 resimden 1. Dell XPS M140 Hard Drive Disk (HDD) Replacement: adım 3, 2 resimden 2.
    • Slide the lock and pull out the battery.
  4. Dell XPS M140 Hard Drive Disk (HDD) Replacement, Hard Disk Drive (HDD): adım 4, 2 resimden 1. Dell XPS M140 Hard Drive Disk (HDD) Replacement, Hard Disk Drive (HDD): adım 4, 2 resimden 2.
    • loosen the two screws that secure the hard drive cover.
    • The screws won’t come out fully. Once you feel like the door is loose enough, it should come right off.
  5. Dell XPS M140 Hard Drive Disk (HDD) Replacement: adım 5, 1 resimden 1.
    • Remove the old HDD from the casing. This is done by simply sliding it out.
Sonuç
Travis Morazzini
207 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G5, Martin Spring 2017 UMass Dartmouth, Team S9-G5, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,074
