Ana içeriğe geç
Dell XPS M140 Screen Replacement
Neye ihtiyacın var
  1. Dell XPS M140 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn over the laptop.
  2. Dell XPS M140 Screen Replacement: adım 2, 3 resimden 1. Dell XPS M140 Screen Replacement: adım 2, 3 resimden 2. Dell XPS M140 Screen Replacement: adım 2, 3 resimden 3.
    • Open the slide lock and pull out the battery.
  3. Dell XPS M140 Screen Replacement, Screen: adım 3, 3 resimden 1. Dell XPS M140 Screen Replacement, Screen: adım 3, 3 resimden 2. Dell XPS M140 Screen Replacement, Screen: adım 3, 3 resimden 3.
    • The plastic casing around the screen has a gray rubber circle, lining the perimeter of the casing.
    • Remove the casing by peeling them off. This will expose the screws underneath.
  4. Dell XPS M140 Screen Replacement: adım 4, 1 resimden 1.
    • Unscrew the screws on the casing that you just exposed.
  5. Dell XPS M140 Screen Replacement: adım 5, 3 resimden 1. Dell XPS M140 Screen Replacement: adım 5, 3 resimden 2. Dell XPS M140 Screen Replacement: adım 5, 3 resimden 3.
    • With care, pop off the plastic clips sourrounding the casing.
    • Run your hand, or a tool, around the perimeter, to remove the casing.
  6. Dell XPS M140 Screen Replacement: adım 6, 3 resimden 1. Dell XPS M140 Screen Replacement: adım 6, 3 resimden 2. Dell XPS M140 Screen Replacement: adım 6, 3 resimden 3.
    • Once the casing is removed, more screws should be exposed.
    • Remove every screw.
  7. Dell XPS M140 Screen Replacement: adım 7, 3 resimden 1. Dell XPS M140 Screen Replacement: adım 7, 3 resimden 2. Dell XPS M140 Screen Replacement: adım 7, 3 resimden 3.
    • Once all of the screws are removed, the screen should be loose.
    • Gently pick it up and place it face down onto the keyboard.
  8. Dell XPS M140 Screen Replacement: adım 8, 3 resimden 1. Dell XPS M140 Screen Replacement: adım 8, 3 resimden 2. Dell XPS M140 Screen Replacement: adım 8, 3 resimden 3.
    • There should be two connections.
    • One with a blue looking handle, and one with clips.
    • To remove the connection with the clips, squeeze the two clips together and pull the ribbon cable.
    • To remove the connection with the blue handle, gently pull on the blue handle, it should come right off.
Sonuç
Travis Morazzini
207 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S9-G5, Martin Spring 2017 UMass Dartmouth, Team S9-G5, Martin Spring 2017 üyesi
UMASSD-MARTIN-S17S9G5
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 355
