Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If your computer is running hot then the fan my be broken or dirty. This guide will help you locate and remove the fan so you can clean or replace it.
Neye ihtiyacın var
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
Flip over the heat sink to remove the four 3.2mm Phillips #000 screws connecting the heat sink to the fan.
Four 3.2mm Phillips #000
2 farklı kişi bu kılavuzu tamamladı.
