Ana içeriğe geç
Dell XPS M1530 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell XPS M1530 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Hard Drive Replacement: adım 3, 2 resimden 1. Dell XPS M1530 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Dell XPS M1530 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Remove the four Phillips #1 screws holding the Hard Drive in place.
    • Four 3.5mm Phillips #1 screws
  5. Dell XPS M1530 Hard Drive Replacement: adım 5, 2 resimden 1. Dell XPS M1530 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
  6. Dell XPS M1530 Hard Drive Replacement: adım 6, 2 resimden 1. Dell XPS M1530 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
    • There is a second screw on the other side of the casing.
    • Then gently separate the drive from its casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler Scholz
479 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-4, Maness Winter 2015 Cal Poly, Team 18-4, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 2,046
