Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the computer upside down with the battery facing you.
Push the switch as far to the right as possible to unlock the battery.
Remove the battery using two hands and pull it away from the computer.
Remove the four Phillips #1 screws holding the Hard Drive in place.
Four 3.5mm Phillips #1 screws
Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
Then gently separate the drive from its casing.
Bir başkası bu kılavuzu tamamladı.
