Ana içeriğe geç
Dell XPS M1530 Wireless Card Replacement
Neye ihtiyacın var
    1. Dell XPS M1530 Wireless Card Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the computer upside down with the battery facing you.
      • Turn the computer off and disconnect the charging cable from the computer.
      • Failure to unplug the charging cable may result in electric shock.
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS M1530 Wireless Card Replacement: adım 2, 1 resimden 1.
      • Push the switch as far to the right as possible to unlock the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS M1530 Wireless Card Replacement: adım 3, 2 resimden 1. Dell XPS M1530 Wireless Card Replacement: adım 3, 2 resimden 2.
      • Remove the battery using two hands and pull it away from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Dell XPS M1530 Wireless Card Replacement, Wireless Card: adım 4, 1 resimden 1.
      • Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
      • Two 4.7mm Philips #1 screws
      FixBot'a Sor
      Yorum Ekle
    2. Dell XPS M1530 Wireless Card Replacement: adım 5, 2 resimden 1. Dell XPS M1530 Wireless Card Replacement: adım 5, 2 resimden 2.
      • Lift the panel up from the indented area.
      • This indent should provide enough grip to remove the panel with ease.
      FixBot'a Sor
      Yorum Ekle
    3. Dell XPS M1530 Wireless Card Replacement: adım 6, 1 resimden 1.
      • Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
      • One 3.9mm Phillips #1 screw
      FixBot'a Sor
      Yorum Ekle
    4. Dell XPS M1530 Wireless Card Replacement: adım 7, 1 resimden 1.
      • Lift the card out at an angle and carefully remove it.
      FixBot'a Sor
      Yorum Ekle
    5. Dell XPS M1530 Wireless Card Replacement: adım 8, 2 resimden 1. Dell XPS M1530 Wireless Card Replacement: adım 8, 2 resimden 2.
      • Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
      • It's best to use an ESD-safe tool, such as a nylon spudger, rather than the metal spudger shown in the photo.
      • Note the order of colors for the antenna cables indicated on the card.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jase Sasaki
721 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-4, Maness Winter 2015 Cal Poly, Team 18-4, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G4
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 2,153
