Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the computer upside down with the battery facing you.
Push the switch as far to the right as possible to unlock the battery.
Remove the battery using two hands and pull it away from the computer.
Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
Two 4.7mm Philips #1 screws
Remove the single 3.9mm Phillips #1 screw in the upper right corner of the wireless card.
One 3.9mm Phillips #1 screw
Lift the card out at an angle and carefully remove it.
Use a spudger to carefully disconnect the antenna cables from the card by prying them straight up off the board.
Bir başkası bu kılavuzu tamamladı.
