Giriş
Before you begin the RAM replacement process, be sure to ground yourself. Grounding yourself prevents short circuiting the device, and/or shocking yourself. An easy way to do so would be to remove one of your shoes.
Neye ihtiyacın var
Remove the two M2x3mm screws from the center panel on the back of computer with a Phillips #0 screwdriver head.
Bir başkası bu kılavuzu tamamladı.
