Ana içeriğe geç
Denim Jeans Inner Thigh Replacement
Neye ihtiyacın var
  1. Denim Jeans Inner Thigh Replacement, Inner Thigh: adım 1, 1 resimden 1.
    • Use a simple back and forth pattern with the needle and thread to close the holes.
    • This step is to ensure the shape of your patch. It will not be the outright fix to the problem.
  2. Denim Jeans Inner Thigh Replacement: adım 2, 3 resimden 1. Denim Jeans Inner Thigh Replacement: adım 2, 3 resimden 2. Denim Jeans Inner Thigh Replacement: adım 2, 3 resimden 3.
    • Use an embroidery hoop as a stencil to trace out the damaged area.
    • Use fabric scissors to cut along the back panel of the jeans. Follow the line.
    • Cut only the back panel or you will have an unnecessary hole in the front of your pants.
  3. Denim Jeans Inner Thigh Replacement: adım 3, 2 resimden 1. Denim Jeans Inner Thigh Replacement: adım 3, 2 resimden 2.
    • Place the cutouts in the denim swatch.
    • Trace a larger shape of the cutout.
    • Use fabric scissors to cut out the patches.
  4. Denim Jeans Inner Thigh Replacement: adım 4, 3 resimden 1. Denim Jeans Inner Thigh Replacement: adım 4, 3 resimden 2. Denim Jeans Inner Thigh Replacement: adım 4, 3 resimden 3.
    • Center the old denim onto the new patch.
    • Trace vertical and horizontal lines on denim by using a straight edge and some chalk.
    • Pin the old denim in place.
  5. Denim Jeans Inner Thigh Replacement: adım 5, 1 resimden 1.
    • Using an embroidery needle and an embroidery floss add stitches into the patch.
    • Use a Straight Stitch (just up and down sewing) following the vertical and then horizontal lines.
    • The embroidery floss comes as a twisted rope. You have to pull the threads from the rope before you can use them.
  6. Denim Jeans Inner Thigh Replacement: adım 6, 1 resimden 1.
    • Pin the patch with as little of the new patch showing as possible.
    • Use a Whip Stitch to attach the patch. This is an over/under sewing pattern.
    • Repeat a second time.
    • Turn inside out and trim down the patch. Use a straight stitch to tighten up any loose spots.
  7. Denim Jeans Inner Thigh Replacement, Finished: adım 7, 1 resimden 1.
    • The style is meant to look rustic and DIY. By no means is it a professional finish. Still functional and if done right can be quite cute!
Sonuç
This is a rustic or unfinished but functional looking patch for denim jeans.
3 farklı kişi bu kılavuzu tamamladı.
chennaultsara
197 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 70
Her zaman: 5,221
