Ana içeriğe geç
Desktop PC Front Fan Replacement
Neye ihtiyacın var
    1. Desktop PC Front Fan Replacement, Left Panel: adım 1, 1 resimden 1.
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      FixBot'a Sor
      Yorum Ekle
    2. Desktop PC Front Fan Replacement: adım 2, 2 resimden 1. Desktop PC Front Fan Replacement: adım 2, 2 resimden 2.
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      FixBot'a Sor
      Yorum Ekle
    1. Desktop PC Front Fan Replacement, Front Fan: adım 3, 2 resimden 1. Desktop PC Front Fan Replacement, Front Fan: adım 3, 2 resimden 2.
      • Push to unlatch three grey connectors on the front panel.
      FixBot'a Sor
      Yorum Ekle
    2. Desktop PC Front Fan Replacement: adım 4, 1 resimden 1.
      • Disconnect the front panel from the computer face.
      FixBot'a Sor
      Yorum Ekle
    3. Desktop PC Front Fan Replacement: adım 5, 1 resimden 1.
      • Remove four Phillips #2 head, 5mm screws holding in the fan.
      FixBot'a Sor
      Yorum Ekle
    4. Desktop PC Front Fan Replacement: adım 6, 1 resimden 1.
      • Slide the fan out from the side of the casing.
      FixBot'a Sor
      Yorum Ekle
    5. Desktop PC Front Fan Replacement: adım 7, 1 resimden 1.
      • Disconnect the power cable from the fan.
      FixBot'a Sor
      Yorum Ekle
Sonuç
39 farklı kişi bu kılavuzu tamamladı.
David Lennon
10.198 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G5
4 Üyeler
89 adet Kılavuz yazıldı
2Kılavuz Yorumları
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - Yanıt Paylaş
I did this with my pc and I was able to restore and add a new fan because the other one wouldn’t work because the wire was snapped so I decided to replace it and this guide helped me
TechNinja - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 34
Son 30 gün: 165
Her zaman: 31,756
