Ana içeriğe geç
Desktop PC GPU Replacement
Neye ihtiyacın var
    1. Desktop PC GPU Replacement, Create an Anti-Static Work Area: adım 1, 1 resimden 1.
      • Minimize exposure to items that can charge up and produce static electricity.
      • Use an anti-static wrist band.
      FixBot'a Sor
      Yorum Ekle
    2. Desktop PC GPU Replacement, Turn Off Computer: adım 2, 1 resimden 1.
      • Power off PC via Windows.
      • Switch off Power Supply
      FixBot'a Sor
      Yorum Ekle
    3. Desktop PC GPU Replacement, Unscrew Case Side Panel: adım 3, 2 resimden 1. Desktop PC GPU Replacement, Unscrew Case Side Panel: adım 3, 2 resimden 2.
      • Put screws where you wont lose them
      FixBot'a Sor
      Yorum Ekle
    4. Desktop PC GPU Replacement, Unplug Power Connector to GPU: adım 4, 1 resimden 1.
      • Be gentle to not pull with to much force when removing power cables.
      FixBot'a Sor
      Yorum Ekle
    5. Desktop PC GPU Replacement, Flip GPU Lock on Motherboard: adım 5, 1 resimden 1.
      • Try not to touch other components.
      FixBot'a Sor
      Yorum Ekle
      • Gently pull the card out of the slot.
      FixBot'a Sor
      Yorum Ekle
    6. Desktop PC GPU Replacement, Insert New GPU: adım 7, 1 resimden 1.
      • Verify that the notch in the connector matches the motherboard before sliding in.
      • Carefully slide in GPU until you hear a click on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. Desktop PC GPU Replacement, Connect Power Cables: adım 8, 1 resimden 1.
      • Insert wisdom here.
      FixBot'a Sor
      Yorum Ekle
    8. Desktop PC GPU Replacement, Re-Attach Side Panel: adım 9, 1 resimden 1.
      • Use same screws from step 2.
      FixBot'a Sor
      Yorum Ekle
      • Flip power supply switch back to on.
      • Plug in PC and turn on.
      • If PC does not post go back through the steps to see if you missed something.
      FixBot'a Sor
      Yorum Ekle
      • Go to manufacturer's website or use the CD that came with the card to download the latest drivers for the GPU to ensure better stability of GPU.
      FixBot'a Sor
      Yorum Ekle
      • Enjoy your new GPU.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joseph Thompson
295 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 25
Son 30 gün: 100
Her zaman: 2,228
