Ana içeriğe geç
Desktop PC Hard Drive Replacement
Neye ihtiyacın var
    1. Desktop PC Hard Drive Replacement, Left Panel: adım 1, 1 resimden 1.
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      FixBot'a Sor
      Yorum Ekle
    2. Desktop PC Hard Drive Replacement: adım 2, 2 resimden 1. Desktop PC Hard Drive Replacement: adım 2, 2 resimden 2.
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      FixBot'a Sor
      Yorum Ekle
    1. Desktop PC Hard Drive Replacement, Right Panel: adım 3, 1 resimden 1.
      • Remove two Phillips #2 head 5mm screws from the back side of the computer case.
      FixBot'a Sor
      Yorum Ekle
    2. Desktop PC Hard Drive Replacement: adım 4, 2 resimden 1. Desktop PC Hard Drive Replacement: adım 4, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    1. Desktop PC Hard Drive Replacement, Hard Drive: adım 5, 1 resimden 1.
      • Remove two Phillips #2 head 5mm screws holding the hard drive in place.
      FixBot'a Sor
      Yorum Ekle
    2. Desktop PC Hard Drive Replacement: adım 6, 1 resimden 1.
      • Remove two Phillips #2 head 5mm screws holding in the other side of the hard drive.
      FixBot'a Sor
      Yorum Ekle
    3. Desktop PC Hard Drive Replacement: adım 7, 1 resimden 1.
      • Slide the hard drive out from the metal casing.
      FixBot'a Sor
      Yorum Ekle
    4. Desktop PC Hard Drive Replacement: adım 8, 1 resimden 1.
      • Remove the cables from the back of the hard drive.
      FixBot'a Sor
      Yorum Ekle
Sonuç
64 farklı kişi bu kılavuzu tamamladı.
Rubin Girling
776 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G5
4 Üyeler
89 adet Kılavuz yazıldı
2Kılavuz Yorumları
Footnote: the processing of removing a drive from your system may vary slightly depending on the manufacturer of your system, or if you built it yourself; the manufacturer of the case.
Jack G - Yanıt Paylaş
Pour remonter l'installation,
-remonter le disque dur faite le glisser dans la cage métallique
- fixer le disque dur avec les vis retirées
-fixer les câbles à l'arrière du disque( câble d'alimentation et nappe de données)
-mettre les panneaux dans l'ordre du retrait
- procéder à l'installation du système d'exploitation...
Rufin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 27
Son 30 gün: 129
Her zaman: 12,530
