Ana içeriğe geç
Desktop PC Left Panel Replacement
Neye ihtiyacın var
  1. Desktop PC Left Panel Replacement, Left Panel: adım 1, 1 resimden 1.
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - Yanıt
    This is correct.
    DistroHopper39B -
  2. Desktop PC Left Panel Replacement: adım 2, 2 resimden 1. Desktop PC Left Panel Replacement: adım 2, 2 resimden 2.
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
David Lennon
9.944 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G5
4 Üyeler
45 adet Kılavuz yazıldı
3 Yorum
What is the name of the case used in this tutorial?
Nicolas Hunter - Yanıt
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - Yanıt
I have this same case in black and want to know what model it is.
numanair - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 90
Her zaman: 5,401
