Ana içeriğe geç
Desktop PC RAM Replacement
Neye ihtiyacın var
  1. Desktop PC RAM Replacement, Left Panel: adım 1, 1 resimden 1.
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC RAM Replacement: adım 2, 2 resimden 1. Desktop PC RAM Replacement: adım 2, 2 resimden 2.
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
  4. Desktop PC RAM Replacement: adım 4, 1 resimden 1.
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
Sonuç
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
53 farklı kişi bu kılavuzu tamamladı.
David Lennon
10.108 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G5
4 Üyeler
45 adet Kılavuz yazıldı
4 Yorum
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - Yanıt
very interesting
maciekErd123 - Yanıt
how to determine the speed
benzy aceware - Yanıt
how can i differentiate between types of rams
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 24
Son 30 gün: 47
Her zaman: 7,555
