Ana içeriğe geç
Motorola RFS4000 Disassembly
  1. Motorola RFS4000 Disassembly, Removing the screw: adım 1, 3 resimden 1. Motorola RFS4000 Disassembly, Removing the screw: adım 1, 3 resimden 2. Motorola RFS4000 Disassembly, Removing the screw: adım 1, 3 resimden 3.
    • Screw
    • Torx T8
    • If you don't have a Torx T8 screwdriver you can use a slotted screwdriver
  2. Motorola RFS4000 Disassembly, Opening the chassis: adım 2, 2 resimden 1. Motorola RFS4000 Disassembly, Opening the chassis: adım 2, 2 resimden 2.
    • Slide up the cover
    • Fan cable
    • Before unscrew you must disconnect the fan cable.
  3. Motorola RFS4000 Disassembly, Removing the fan: adım 3, 3 resimden 1. Motorola RFS4000 Disassembly, Removing the fan: adım 3, 3 resimden 2. Motorola RFS4000 Disassembly, Removing the fan: adım 3, 3 resimden 3.
    • Fan chassis screws
    • Fan screws
    • Reset Button
    • Power Inlet
  4. Motorola RFS4000 Disassembly, Removing the motherboard: adım 4, 3 resimden 1. Motorola RFS4000 Disassembly, Removing the motherboard: adım 4, 3 resimden 2. Motorola RFS4000 Disassembly, Removing the motherboard: adım 4, 3 resimden 3.
    • Motherboard screws
    • RJ45 ports
    • Console port (rj45) and usb port
    • Express card
    • SFP port (Motorola part number: Fiber-3000-1S-WWR)
    • Reset button
Sonuç
Para reensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
Bir başkası bu kılavuzu tamamladı.
Eneider Colina
2.362 İtibar
9 adet Kılavuz yazıldı
Ekip
Comunidad para traductores de español Comunidad para traductores de español üyesi
Community
23 Üyeler
225 adet Kılavuz yazıldı
Bir Yorum
No, it's better not to use a slotted screwdriver, because the screws are tightened quite tight (if they haven't already been unscrewed) and you destroy the screws with them. Time required 30 minutes :-))? 10-15 maybe
omanoman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 266
