Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
Use your other hand to push down on the yellow button on the battery.
Pull the battery in a horizontal direction away from the drill.
Lay the drill on its side and gently lift the top half off it.
Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
