Ana içeriğe geç
Dewalt DCF885 Brush Assembly Replacement
Neye ihtiyacın var
  1. Dewalt DCF885 Brush Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Press the battery release button at the top of the battery.
  2. Dewalt DCF885 Brush Assembly Replacement: adım 2, 1 resimden 1.
    • Pull the battery away from the tool.
  3. Dewalt DCF885 Brush Assembly Replacement, Motor Assembly: adım 3, 1 resimden 1.
    • Remove the eight 18 mm Torx Security #10 screws.
  4. Dewalt DCF885 Brush Assembly Replacement: adım 4, 1 resimden 1.
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. Dewalt DCF885 Brush Assembly Replacement: adım 5, 1 resimden 1.
    • Disconnect the connector from the motor assembly.
  6. Dewalt DCF885 Brush Assembly Replacement: adım 6, 1 resimden 1.
    • Pull the motor away from the brush assembly.
  7. Dewalt DCF885 Brush Assembly Replacement, Brush Assembly: adım 7, 1 resimden 1.
    • Lift the brush assembly out of the drill case.
  8. Dewalt DCF885 Brush Assembly Replacement: adım 8, 1 resimden 1.
    • Pull the armature assembly apart from the brush ring assembly.
  9. Dewalt DCF885 Brush Assembly Replacement: adım 9, 1 resimden 1.
    • Pry the two circled connectors apart from the brush ring assembly.
  10. Dewalt DCF885 Brush Assembly Replacement: adım 10, 1 resimden 1.
    • The brush assembly is now removed from the drill body.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Can you tell me the exact model number of the unit in this tutorial? And/Or the part number for that switch assembly? I cannot find that specific switch assembly anywhere! Thank you.
Derek Tombrello - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 2,222
