Ana içeriğe geç
Dewalt DCF885 Motor Assembly Replacement
Neye ihtiyacın var
  1. Dewalt DCF885 Motor Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Press the battery release button at the top of the battery.
  2. Dewalt DCF885 Motor Assembly Replacement: adım 2, 1 resimden 1.
    • Pull the battery away from the tool.
  3. Dewalt DCF885 Motor Assembly Replacement, Motor Assembly: adım 3, 1 resimden 1.
    • Remove the eight 18 mm Torx Security #10 screws.
  4. Dewalt DCF885 Motor Assembly Replacement: adım 4, 1 resimden 1.
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. Dewalt DCF885 Motor Assembly Replacement: adım 5, 1 resimden 1.
    • Disconnect the connector from the motor assembly.
  6. Dewalt DCF885 Motor Assembly Replacement: adım 6, 1 resimden 1.
    • Pull the motor away from the brush assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 43
Her zaman: 2,430
