Ana içeriğe geç
Dewalt DW511 Hammer Drill Gearcase Replacement
Neye ihtiyacın var
  1. Dewalt DW511 Hammer Drill Gearcase Replacement, Back Cover: adım 1, 3 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement, Back Cover: adım 1, 3 resimden 2. Dewalt DW511 Hammer Drill Gearcase Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 2, 3 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 2, 3 resimden 2. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 2, 3 resimden 3.
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. Dewalt DW511 Hammer Drill Gearcase Replacement, Power Cord: adım 3, 2 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement, Power Cord: adım 3, 2 resimden 2.
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 4, 3 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 4, 3 resimden 2. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 5, 3 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 5, 3 resimden 2. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 5, 3 resimden 3.
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 6, 1 resimden 1.
    • With both wires free, the power cord is free from the trigger body.
  7. Dewalt DW511 Hammer Drill Gearcase Replacement, Brushes: adım 7, 3 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement, Brushes: adım 7, 3 resimden 2. Dewalt DW511 Hammer Drill Gearcase Replacement, Brushes: adım 7, 3 resimden 3.
    • Use an opening tool to lift up the spring holding down the brush.
    • Remove the brush from its holding.
  8. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 8, 2 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 8, 2 resimden 2.
    • With a pair of blunt nose tweezers, grab the red wire.
  9. Dewalt DW511 Hammer Drill Gearcase Replacement, Lever Assembly: adım 9, 3 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement, Lever Assembly: adım 9, 3 resimden 2. Dewalt DW511 Hammer Drill Gearcase Replacement, Lever Assembly: adım 9, 3 resimden 3.
    • Remove two 45 mm T20 Torx screws.
    • Remove one 30 mm T20 Torx screw.
  10. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 10, 1 resimden 1.
    • Pull off the top case and set it aside.
  11. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 11, 3 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 11, 3 resimden 2. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 11, 3 resimden 3.
    • Grab the gear case cover and gently pull it out just enough to where it exposes the lever assembly.
    • It is important that the brushes are removed before you do this step or you may damage your brushes.
    • The lever assembly can now be lifted out.
  12. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 12, 1 resimden 1.
    • With the old lever assembly removed you can now replace it with a new one.
  13. Dewalt DW511 Hammer Drill Gearcase Replacement, Gearcase: adım 13, 3 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement, Gearcase: adım 13, 3 resimden 2. Dewalt DW511 Hammer Drill Gearcase Replacement, Gearcase: adım 13, 3 resimden 3.
    • Hold the hammer drill tool firmly by the handle.
    • Gently separate the gear case unit from the hammer drill body.
  14. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 14, 3 resimden 1. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 14, 3 resimden 2. Dewalt DW511 Hammer Drill Gearcase Replacement: adım 14, 3 resimden 3.
    • The metallic alloy gear case is attached to the armature and removes as a unit. Separation of the gear case from the armature requires specialized hand tools.
    • The third photo shows a gear behind the chuck that interlocks to the gear case.
    • The plastic housing is prone to damage if excessive force is applied during the removal of the gear.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 473
