Giriş
This guide shows how to remove and replace the PTO assembly for the Dewalt Nailers DCN680D1. The replacement part does not come with some minor components, so you must transfer them from the original part.
Neye ihtiyacın var
Remove the following screws securing the outer housing:
Twelve T10 screws
One 2.5 mm hex screw
Carefully flip the device over.
Remove the left housing from the device.
Use a T20 driver to remove the two screws (one on either side) securing the back support .
Slide the dowel pin securing the PTO assembly out of the device.
Use a T10 driver to remove the two screws securing the solenoid.
Reassembly tip: When you slide the solenoid back onto the PTO assembly, make sure to align the plastic pin to the notch.
Use a flathead screwdriver to pry off the rubber stopper securing the plunger pin.
