Ana içeriğe geç
Dexcom G6 Receiver Speaker Replacement
Neye ihtiyacın var
  1. Dexcom G6 Receiver Speaker Replacement, Display and Front Bezel: adım 1, 1 resimden 1.
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Speaker Replacement: adım 2, 2 resimden 1. Dexcom G6 Receiver Speaker Replacement: adım 2, 2 resimden 2.
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Speaker Replacement, Charging Port: adım 3, 1 resimden 1.
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Speaker Replacement, Motherboard: adım 6, 1 resimden 1.
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Speaker Replacement: adım 7, 2 resimden 1. Dexcom G6 Receiver Speaker Replacement: adım 7, 2 resimden 2.
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Speaker Replacement: adım 8, 1 resimden 1.
    • Using a spudger, carefully pry up the motherboard to remove it.
  9. Dexcom G6 Receiver Speaker Replacement, Speaker: adım 9, 1 resimden 1.
    • Using a spudger, carefully pry up and remove the speaker at the top.
    • Remove any remaining adhesive.
    • Put down new adhesive tape(be careful not to let it get in the way of the speaker).
    • Stick the new speaker down.
Sonuç
Andrew S
15.537 İtibar
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 303
