Ana içeriğe geç
Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable
Neye ihtiyacın var
  1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable, Unplug: adım 1, 1 resimden 1.
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 2, 2 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 2, 2 resimden 2.
    • Remove the dust case and the seal on the back of the device.
  3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 3, 3 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 3, 3 resimden 2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 3, 3 resimden 3.
    • Unscrew the six screws from the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 4, 2 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 4, 2 resimden 2.
    • Using a screwdriver or screwdriver, unscrew and open the device.
  5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 5, 2 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 5, 2 resimden 2.
    • Unscrew the two screws from the domino to pull out the brown and blue cables.
  6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 6, 2 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 6, 2 resimden 2.
    • Reconnect the new cable to the domino.
    • Then replace the cable, the sheath must arrive between the two pads and the sleeve must be positioned in its housing.
  7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 7, 3 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 7, 3 resimden 2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 7, 3 resimden 3.
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  8. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 8, 2 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 8, 2 resimden 2.
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  9. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Power Cable: adım 9, 1 resimden 1.
    • Finally, reposition the vacuum bag.
Bitiş Çizgisi
Bu çevirmenlere özel teşekkürler:
fr en
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Céline Chemineau
16.581 İtibar
95 adet Kılavuz yazıldı
Ekip
Leroy Merlin Leroy Merlin üyesi
Community
36 Üyeler
239 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 140
