Ana içeriğe geç
Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser
Neye ihtiyacın var
  1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser, Unplug: adım 1, 1 resimden 1.
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 2, 2 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 2, 2 resimden 2.
    • Remove the dust case on the back of the device.
  3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 3, 3 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 3, 3 resimden 2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 3, 3 resimden 3.
    • Unscrew the six screws from the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 4, 2 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 4, 2 resimden 2.
    • Remove the four stabilisers by hand.
  5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 5, 2 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 5, 2 resimden 2.
    • The stabilisers make sense, so be careful when replacing them.
    • Replace them directly on the pad for ease.
  6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 6, 2 resimden 1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 6, 2 resimden 2.
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: adım 7, 1 resimden 1.
    • Finally, reposition the vacuum bag.
Bitiş Çizgisi
Bu çevirmenlere özel teşekkürler:
fr en
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Céline Chemineau
16.581 İtibar
95 adet Kılavuz yazıldı
Ekip
Leroy Merlin Leroy Merlin üyesi
Community
36 Üyeler
239 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 383
