Ana içeriğe geç
Dexter 750W Wired Jigsaw Power Cable Replacement
Neye ihtiyacın var
  1. Dexter 750W Wired Jigsaw Power Cable Replacement, Unplug: adım 1, 1 resimden 1.
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 2, 1 resimden 1.
    • Remove the vacuum adaptor on the back of the device.
  3. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 3, 2 resimden 1. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 3, 2 resimden 2.
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
  4. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 4, 1 resimden 1.
    • Remove the two screws to unlock the cable.
  5. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 5, 1 resimden 1.
    • Remove the black screw, in order to remove the wheel.
    • Thanks to a screwdriver, leverage to be able to recover the wheel.
  6. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 7, 2 resimden 1. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 7, 2 resimden 2.
    • Turn the switch over.
    • Unscrew the 2 screws to remove the blue and brown cables.
  7. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 8, 1 resimden 1.
    • Reconnect the new cable.
    • The brown thread must be at the top and the blue thread must be at the bottom.
  8. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 9, 2 resimden 1. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 9, 2 resimden 2.
    • Reposition each room in its housing.
    • Then screw each screw.
  9. Dexter 750W Wired Jigsaw Power Cable Replacement: adım 10, 1 resimden 1.
    • Close and screw the device.
Bitiş Çizgisi
Bu çevirmenlere özel teşekkürler:
fr en
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Céline Chemineau
16.608 İtibar
95 adet Kılavuz yazıldı
Ekip
Leroy Merlin Leroy Merlin üyesi
Community
37 Üyeler
239 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 300
