Ana içeriğe geç
Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable
Neye ihtiyacın var
  1. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable, Unplug: adım 1, 1 resimden 1.
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 2, 2 resimden 1. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 2, 2 resimden 2.
    • Unscrew the screws of the hull to open it.
  3. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 3, 2 resimden 1. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 3, 2 resimden 2.
    • Unscrew the cable clamp.
  4. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 4, 1 resimden 1.
    • Remove the two screws from the switch.
    • Then remove the cable.
  5. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 5, 3 resimden 1. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 5, 3 resimden 2. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 5, 3 resimden 3.
    • Reconnect the new cable to the switch, then tighten the cable clamp.
  6. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 6, 2 resimden 1. Dexter 900W Corded Reciprocating Saw - 900RPS Replacement Power Cable: adım 6, 2 resimden 2.
    • Before closing, check that no cable is blocked and that each part is in its place.
    • Then retighten the hull screws.
Sonuç
By the end of the guide you will have successfully replaced your power cable
Bu çevirmenlere özel teşekkürler:
fr en
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Céline Chemineau
16.497 İtibar
95 adet Kılavuz yazıldı
Ekip
Leroy Merlin Leroy Merlin üyesi
Community
36 Üyeler
239 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 117
