Ana içeriğe geç
Dexter Corded Belt Sander - 900BS2.5 Motor Replacement
Neye ihtiyacın var
  1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement, Unplug: adım 1, 1 resimden 1.
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 2, 3 resimden 1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 2, 3 resimden 2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 2, 3 resimden 3.
    • Remove the handle, by unscrewing the screw.
  3. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 3, 2 resimden 1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 3, 2 resimden 2.
    • Pry the tape off.
  4. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 4, 1 resimden 1.
    • Unscrew the 4 screws.
  5. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 5, 2 resimden 1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 5, 2 resimden 2.
    • Remove the belt, then unscrew the screws of the shell to gain access to the motor.
    • Collect the belt to place it in the new room.
  6. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 6, 3 resimden 1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 6, 3 resimden 2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 6, 3 resimden 3.
    • Remove both accessories.
  7. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 7, 2 resimden 1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 7, 2 resimden 2.
    • Remove the screws from the hull in order to have access to the interior and allow the carbon brushes to be blocked.
    • Relax the small metal strip to be able to separate the carbons.
    • Replace the new part in its housing.
  8. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 10, 2 resimden 1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 10, 2 resimden 2.
    • Open the cap of the new part to replace the belt.
    • Tighten the inner screw.
  9. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 11, 1 resimden 1.
    • Tighten the four screws.
  10. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 12, 3 resimden 1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 12, 3 resimden 2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: adım 12, 3 resimden 3.
    • Replace the tip, band and handle.
Bitiş Çizgisi
Bu çevirmenlere özel teşekkürler:
fr en
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Céline Chemineau
16.581 İtibar
95 adet Kılavuz yazıldı
Ekip
Leroy Merlin Leroy Merlin üyesi
Community
36 Üyeler
239 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 111
