Ana içeriğe geç
Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System
Neye ihtiyacın var
  1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System, Unplug: adım 1, 1 resimden 1.
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 2, 3 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 2, 3 resimden 2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 2, 3 resimden 3.
    • Remove the handle, unscrewing the screw
  3. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 3, 2 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 3, 2 resimden 2.
    • Remove the strip by leverling
  4. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 4, 1 resimden 1.
    • Remove the front cover to have more space.
  5. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 5, 1 resimden 1.
    • Remove the two screws on the shell.
  6. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 6, 1 resimden 1.
    • Turn the machine over and unscrew the large screw.
    • Unscrew the orange wheel to be able to lift it.
  7. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 8, 1 resimden 1.
    • Remove the spring from the old part to put it back on the new one.
  8. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 9, 1 resimden 1.
    • Put the spring back.
    • Tighten the orange wheel.
  9. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 11, 1 resimden 1.
    • Put the two screws back on the side and the large screw.
  10. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 12, 3 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 12, 3 resimden 2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: adım 12, 3 resimden 3.
    • Replace the tip, strip and handle.
Bitiş Çizgisi
Bu çevirmenlere özel teşekkürler:
fr en
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Céline Chemineau
16.581 İtibar
95 adet Kılavuz yazıldı
Ekip
Leroy Merlin Leroy Merlin üyesi
Community
36 Üyeler
239 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 301
