Ana içeriğe geç
Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable
Neye ihtiyacın var
  1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable, Unplug: adım 1, 1 resimden 1.
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 2, 3 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 2, 3 resimden 2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 2, 3 resimden 3.
    • Remove the handle, by unscrewing the screw.
  3. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 3, 2 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 3, 2 resimden 2.
    • Remove the strip by leverling.
  4. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 4, 1 resimden 1.
    • Unscrew the 4 screws.
  5. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 5, 2 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 5, 2 resimden 2.
    • Remove the belt, then unscrew the screws from the shell to access the engine.
  6. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 6, 2 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 6, 2 resimden 2.
    • Remove the screws from the hull to have access inside and allow the coals to be blocked.
    • Lift the speed variator, you can use a small screwdriver to get it out.
  7. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 8, 2 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 8, 2 resimden 2.
    • Turn the dimmer over to have good access to be able to unweld the wires.
    • Unweld the cables connected to the motor and suck the excess with a pump.
  8. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 10, 3 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 10, 3 resimden 2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 10, 3 resimden 3.
    • Unscrew the two screws from the switch to extract the second cable.
    • To extract the cables you can use a clamp.
    • Change the speed variator and then disconnect the cable from the switch.
    • Reseating the motor cables to the dimmer.
  9. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 13, 3 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 13, 3 resimden 2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 13, 3 resimden 3.
    • Replace the dimmer in its housing.
    • Be careful to put the cables back on so that it is not pinched.
  10. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 14, 1 resimden 1.
    • Screw the four screws.
  11. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 15, 3 resimden 1. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 15, 3 resimden 2. Dexter Wired Belt Sander - 900BS2.5 Replacement Speed Variable: adım 15, 3 resimden 3.
    • Replace the tip, strip and handle.
Bitiş Çizgisi
Bu çevirmenlere özel teşekkürler:
fr en
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Céline Chemineau
16.581 İtibar
95 adet Kılavuz yazıldı
Ekip
Leroy Merlin Leroy Merlin üyesi
Community
36 Üyeler
239 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 143
