Ana içeriğe geç
Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement
Neye ihtiyacın var
  1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement, Unplug: adım 1, 1 resimden 1.
    • Before you start, remember to disconnect the outlet from the mains.
  2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 2, 2 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 2, 2 resimden 2.
    • Remove the dust box and the seal on the back of the device.
  3. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 3, 3 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 3, 3 resimden 2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 3, 3 resimden 3.
    • Unscrew the six screws of the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 4, 2 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 4, 2 resimden 2.
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Lift the two carbons with a screwdriver to get them out of their homes.
    • Remove the rotor from its housing.
    • Press the tab to disconnect the coal from the engine.
    • Unscrew the domino screws to disconnect the cables.
    • Use a clamp to extract the cables.
  5. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 9, 1 resimden 1.
    • Separate the wire connected to the motor.
    • Cut the rat cable with a cutting pliers.
  6. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 11, 2 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 11, 2 resimden 2.
    • Unsolder the cable connected to the speed dimmer.
    • Approach the soldering iron to heat the tin and make it soft. Using the pump, remove the residues.
  7. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 13, 1 resimden 1.
    • Take out the old engine to replace it with the new one.
  8. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 14, 3 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 14, 3 resimden 2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 14, 3 resimden 3.
    • Replace the cable of the new motor on the speed dimmer.
    • You must take the shortest cable.
    • With tin, unsolder the wire on the frame to hold it.
    • Replace the speed dimmer in its housing.
  9. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 17, 3 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 17, 3 resimden 2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 17, 3 resimden 3.
    • Replace the most black thread in the domino.
  10. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 18, 1 resimden 1.
    • Replace each room in its housing.
    • Reconnect the carbons.
  11. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 20, 2 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 20, 2 resimden 2.
    • Replace the new engine.
    • Remember to recover the small washer at the end of the old piece.
  12. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 21, 1 resimden 1.
    • Replace the engine at its location.
  13. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 22, 3 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 22, 3 resimden 2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 22, 3 resimden 3.
    • Be careful to put the black cable back into its housing so as not to block during the reassembly of the machine.
    • Put the carbons back in their place.
  14. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 24, 3 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 24, 3 resimden 2. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 24, 3 resimden 3.
    • Replace the shell, then screw it back on.
    • Remember to put the joint back in its place.
  15. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 25, 2 resimden 1. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 25, 2 resimden 2.
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  16. Dexter Wired Vibrating Sander 330W - 330SHS2.5 Engine Replacement: adım 26, 1 resimden 1.
    • Finally, reposition the vacuum bag.
Bitiş Çizgisi
Bu çevirmenlere özel teşekkürler:
fr en
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Céline Chemineau
16.581 İtibar
95 adet Kılavuz yazıldı
Ekip
Leroy Merlin Leroy Merlin üyesi
Community
36 Üyeler
239 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 149
