Ana içeriğe geç
Diagnosing and Erasing Hard Drives
Neye ihtiyacın var
  1. Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: adım 1, 3 resimden 1. Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: adım 1, 3 resimden 2. Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: adım 1, 3 resimden 3.
    • This guide assumes the boot drive has been created beforehand. If you need instructions on how to make a bootable USB, Refer to this guide.
    • If you are testing an M.2 SSD (AHCI or NVMe), you will need an enclosure specially built for this. This is not shown in this guide as M.2 was not as prevalent when I wrote this guide.
    • Connect the drive internally to your PC (SATA port or secondary M.2 slot), or to a USB drive adapter.
    • If the hard drive is not installed and you do not have a USB adapter, it can be plugged into a motherboard.
  2. Diagnosing and Erasing Hard Drives, Ubuntu - POH/POC Check: adım 2, 3 resimden 1. Diagnosing and Erasing Hard Drives, Ubuntu - POH/POC Check: adım 2, 3 resimden 2. Diagnosing and Erasing Hard Drives, Ubuntu - POH/POC Check: adım 2, 3 resimden 3.
    • While high hours are not an indication of failure, the odds of a failure are much higher.
    • GSmartControl can be used in Ubuntu if you cannot read the output from Disks.
    • Boot your system into a live Ubuntu session. Locate the Disks application and select the suspicious hard drive.
    • From the drop-down menu, select SMART Data and Self Tests. This will pull up the SMART data.
    • Locate the following SMART attributes: Power On Hours and Power Cycle Count.
  3. Diagnosing and Erasing Hard Drives, Ubuntu - Reallocated sectors and SMART testing: adım 3, 3 resimden 1. Diagnosing and Erasing Hard Drives, Ubuntu - Reallocated sectors and SMART testing: adım 3, 3 resimden 2. Diagnosing and Erasing Hard Drives, Ubuntu - Reallocated sectors and SMART testing: adım 3, 3 resimden 3.
    • If the Reallocated Sector Count is highlighted with a high count, REPLACE THE DRIVE; they are prone to failure and unexpected capacity loss! While SMART Extended is better, a quick test may be sufficient.
    • Locate the following SMART attributes: Reallocated sector count; Current pending sector count.
    • To run a SMART Extended Self-Test, left click Start Self-Test. Select Extended from the drop-down menu.
  4. Diagnosing and Erasing Hard Drives, Parted Magic - POH/POC check: adım 4, 3 resimden 1. Diagnosing and Erasing Hard Drives, Parted Magic - POH/POC check: adım 4, 3 resimden 2. Diagnosing and Erasing Hard Drives, Parted Magic - POH/POC check: adım 4, 3 resimden 3.
    • Select Disks from the desktop to open GSmartControl.
    • Select the hard disk you want to test. Click Attributes to read the SMART data.
    • Locate the following attributes: Power On Time and Power Cycle Count.
  5. Diagnosing and Erasing Hard Drives, Parted Magic - Reallocated sectors and SMART testing: adım 5, 3 resimden 1. Diagnosing and Erasing Hard Drives, Parted Magic - Reallocated sectors and SMART testing: adım 5, 3 resimden 2. Diagnosing and Erasing Hard Drives, Parted Magic - Reallocated sectors and SMART testing: adım 5, 3 resimden 3.
    • In the Attributes tab, locate the following SMART attributes: Reallocated Sector Count; Reallocation Event Count; Current Pending Sector Count.
    • To test the drive, select Perform Tests. Click Test type: and select Extended Self-Test.
  6. Diagnosing and Erasing Hard Drives, Parted Magic - Error log check: adım 6, 3 resimden 1. Diagnosing and Erasing Hard Drives, Parted Magic - Error log check: adım 6, 3 resimden 2. Diagnosing and Erasing Hard Drives, Parted Magic - Error log check: adım 6, 3 resimden 3.
    • Use the error log and SMART data together to diagnose drive problems.
    • Check the error log for drive errors. Click the Error log tab, and review the logs.
    • In the Error log, review the available errors. Read these logs if any are found.
  7. Diagnosing and Erasing Hard Drives, Parted Magic - Erasing hard drives: adım 7, 3 resimden 1. Diagnosing and Erasing Hard Drives, Parted Magic - Erasing hard drives: adım 7, 3 resimden 2. Diagnosing and Erasing Hard Drives, Parted Magic - Erasing hard drives: adım 7, 3 resimden 3.
    • When possible, avoid using "sector wipe" on SSDs. This will eat into the TBW of the drive, which can cause problems on older 75TBW drives.
    • The options available here that will work will vary based on what is supported by the firmware on the drive.
    • CAUTION: Drives with known issues in the firmware around the ATA Secure Erase option may be bricked depending on the severity (and risk). If you use this on a drive with known problems, it can potentially brick the drive. When in doubt, select EXTERNAL for safety (at the expense of time/NAND flash wear on SSDs).
    • IF the drive does not support ATA Secure Erase (primarily older drives), you will need to select External and use Nwipe to erase it. The best middle ground in Nwipe/DBAN is "DoD Short (3 pass+blanking).
    • AHCI drives (M.2 SATA/2.5" drives/3.5" drives) When possible for security (and in the case of SSDs, reduced or mitigated drive wear), try to use the ATA Secure Erase option when possible, unless the drive has known bugs (see warning above).
    • NVMe SSD Recomendation: When possible, use NVMe secure erase. This is instant because it destroys the encryption key on these drives so the data can no longer be read and does not need to zero out the entire drive.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Nick
93.833 İtibar
59 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 62
Her zaman: 2,485
