Ana içeriğe geç
DigiLand DL1010Q Motherboard Replacement
Neye ihtiyacın var
  1. DigiLand DL1010Q Motherboard Replacement, Rear Case: adım 1, 1 resimden 1.
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Motherboard Replacement: adım 2, 2 resimden 1. DigiLand DL1010Q Motherboard Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Motherboard Replacement: adım 3, 1 resimden 1.
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
  4. DigiLand DL1010Q Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Using a plastic opening tool, gently pry up the three Zero Insertion Force Connectors (ZIF)
  5. DigiLand DL1010Q Motherboard Replacement: adım 5, 2 resimden 1. DigiLand DL1010Q Motherboard Replacement: adım 5, 2 resimden 2.
    • Using a Soldering station, desolder all 9 wires connected to the motherboard.
    • Start with the red and black positive and negative wires connected to the battery (2 wires).
    • Then move to the yellow and red twisted wires and black and red twisted wires connected to the speakers (4 wires).
    • Now desolder the single grey wire connected to the antenna (1 wire).
    • Lastly remove the black and red wires connected to the microphone (2 wires).
  6. DigiLand DL1010Q Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a J00 Philips screwdriver, unscrew the three black 4mm screws from the motherboard.
  7. DigiLand DL1010Q Motherboard Replacement: adım 7, 2 resimden 1. DigiLand DL1010Q Motherboard Replacement: adım 7, 2 resimden 2.
    • Carefully lift motherboard in a upward motion.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
How can I remove the CMOS battery?
solomon A.O - Yanıt
I NEED dl1010q MOTHER BOARD
myukimages - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 1,073
