Ana içeriğe geç
DigiLand DL1010Q Rear Case Replacement
Neye ihtiyacın var
  1. DigiLand DL1010Q Rear Case Replacement, Rear Case: adım 1, 1 resimden 1.
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Rear Case Replacement: adım 2, 2 resimden 1. DigiLand DL1010Q Rear Case Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Rear Case Replacement: adım 3, 1 resimden 1.
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 507
