Ana içeriğe geç
DigiLand DL701Q Back Case Replacement
Neye ihtiyacın var
  1. DigiLand DL701Q Back Case Replacement, Back Case: adım 1, 3 resimden 1. DigiLand DL701Q Back Case Replacement, Back Case: adım 1, 3 resimden 2. DigiLand DL701Q Back Case Replacement, Back Case: adım 1, 3 resimden 3.
    • Make sure your device is turned off.
    • Hold the device firmly, in landscape view.
    • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
    • Some force may need to be applied and there may be a cracking sound. This is normal.
    • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
    • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
  2. DigiLand DL701Q Back Case Replacement: adım 2, 3 resimden 1. DigiLand DL701Q Back Case Replacement: adım 2, 3 resimden 2. DigiLand DL701Q Back Case Replacement: adım 2, 3 resimden 3.
    • Place the screen in the palm of your hand and then with your other hand carefully grab the case and remove the cover like flipping the page of a book.
    • Lay the device down and notice that the speaker will be attached to the back cover with a wire. Carefully lift the speaker upward from the back cover and place it near the battery.
    • The speaker may be glued in so treat with care and remove the speaker by gently moving your finger around it and lifting up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jonathan Mysona
1.135 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-1, Benson Spring 2016 Clemson, Team 6-1, Benson Spring 2016 üyesi
CLEM-BENSON-S16S6G1
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 881
