Ana içeriğe geç
DigiLand DL8006 Motherboard Replacement
Neye ihtiyacın var
    1. DigiLand DL8006 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. DigiLand DL8006 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
      • Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. DigiLand DL8006 Motherboard Replacement: adım 2, 1 resimden 1.
      • Peel back the metallic tape connecting the motherboard to the tablet body with your fingers.
      FixBot'a Sor
      Yorum Ekle
    3. DigiLand DL8006 Motherboard Replacement: adım 3, 3 resimden 1. DigiLand DL8006 Motherboard Replacement: adım 3, 3 resimden 2. DigiLand DL8006 Motherboard Replacement: adım 3, 3 resimden 3.
      • Remove the battery plug from the motherboard.
      • Fingers may be used to gently wiggle the connector out if it becomes stuck.
      • If battery wires are under the ribbon, Do Step #4 first.
      FixBot'a Sor
      Yorum Ekle
    4. DigiLand DL8006 Motherboard Replacement: adım 4, 2 resimden 1. DigiLand DL8006 Motherboard Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Opening the locking tab of the ZIF connector and carefully remove the upper section of the ribbon cable from the motherboard using tweezers.
      FixBot'a Sor
      Yorum Ekle
    5. DigiLand DL8006 Motherboard Replacement: adım 5, 2 resimden 1. DigiLand DL8006 Motherboard Replacement: adım 5, 2 resimden 2.
      • Disconnect the three remaining ribbons by opening the locking tabs of the ZIF connectors and gently pulling the cables out.
      • Use tweezers to manipulate the connectors and ribbons to prevent damage.
      FixBot'a Sor
      Yorum Ekle
    6. DigiLand DL8006 Motherboard Replacement: adım 6, 3 resimden 1. DigiLand DL8006 Motherboard Replacement: adım 6, 3 resimden 2. DigiLand DL8006 Motherboard Replacement: adım 6, 3 resimden 3.
      • Remove the 3 mounting screws from the motherboard with a Phillips #0 screwdriver.
      • One of the screws is located under a ribbon. You will need to gently peel back the cable to access it (see image 3).
      FixBot'a Sor
      Yorum Ekle
    7. DigiLand DL8006 Motherboard Replacement: adım 7, 1 resimden 1.
      • Gently remove the motherboard from the case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alec Trela
327 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 481
