Giriş
This guide will demonstrate how to replace to the DigiLand DL8006's motherboard. If your device is is experiencing frequent freezes and system lockups, and you have determined that it is not the fault of the RAM, power supply, or CPU, you may need to replace your motherboard. Make sure that you save your data on a separate device, as all the locally stored date will be removed when your motherboard is replaced.
Neye ihtiyacın var
Remove the backing of the tablet to reveal the internal components using a plastic opening tool.
Bir başkası bu kılavuzu tamamladı.
