Ana içeriğe geç
DigiLand DL8006 Speaker Replacement
Neye ihtiyacın var
  1. DigiLand DL8006 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Begin by opening the device around its edge using the iFixit opening tool.
  2. DigiLand DL8006 Speaker Replacement: adım 2, 2 resimden 1. DigiLand DL8006 Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the metallic tape that covers the lower section of the battery.
  3. DigiLand DL8006 Speaker Replacement: adım 3, 2 resimden 1. DigiLand DL8006 Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the three battery screws using a Phillips #0 screwdriver.
  4. DigiLand DL8006 Speaker Replacement: adım 4, 3 resimden 1. DigiLand DL8006 Speaker Replacement: adım 4, 3 resimden 2. DigiLand DL8006 Speaker Replacement: adım 4, 3 resimden 3.
    • Pop up the locking tab of the ZIF connector using tweezers, and carefully pull the cable out from the motherboard.
    • Make sure the ribbon passes under the microphone wiring to avoid damage to the components.
    • Remove the lower section of the ribbon cable repeating the previous bullet.
  5. DigiLand DL8006 Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the phone using the iFixit opening tool or the spudger.
  6. DigiLand DL8006 Speaker Replacement: adım 6, 2 resimden 1. DigiLand DL8006 Speaker Replacement: adım 6, 2 resimden 2.
    • Finally, remove the speaker from the tablet using the spudger.
    • In this image, a screwdriver was used to pry the speaker from its housing. You should use an ESD-safe tool to avoid causing damage to your device.
Sonuç
Alec Trela
327 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 136
