Giriş
This guide will walk you through the process of replacing your DigiLand Dl801W microphone. Be careful as you complete the steps listed in this guide. If a component is not coming out smoothly, make sure that all screws that need to be removed were removed.
Note: Light soldering is required for successful repair of the microphone of the DigiLand Dl801W.
Neye ihtiyacın var
Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
Bir başkası bu kılavuzu tamamladı.
