Giriş
This guide will show you the process of replacing your DigiLand Dl801W power button components. There are quite a few steps, so take your time and follow them carefully.
Note: Light soldering is required for successful repair of the power button components of the DigiLand Dl801W.
Neye ihtiyacın var
Hold the tablet in one hand (not your primary hand) so that the bottom edge of the tablet is facing you and the back of the tablet is facing up.
Using a blue plastic opening tool, gently insert the tool between the back panel and the main body.
Going around the edge of the tablet, gently pry open the back panel. As you go around, you will hear a click.
