Ana içeriğe geç
Digitac Jazz Ultratab C725 Charging Port Replacement
Neye ihtiyacın var
  1. Digitac Jazz Ultratab C725 Charging Port Replacement, Charging Port: adım 1, 3 resimden 1. Digitac Jazz Ultratab C725 Charging Port Replacement, Charging Port: adım 1, 3 resimden 2. Digitac Jazz Ultratab C725 Charging Port Replacement, Charging Port: adım 1, 3 resimden 3.
    • Locate the four 3.5 mm Phillips head screws holding the silver back plate and the screen together. There are 2 screws on the top and another 2 screws on the bottom.
    • Remove all four screws with the Phillips #00 screwdriver.
    • Remove the screws with the least amount of force. The removal of the screw will be more difficult if thread damage occurs.
  2. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 2, 3 resimden 1. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 2, 3 resimden 2. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 2, 3 resimden 3.
    • Flip your device so that the long side without the buttons is facing you.
    • Insert the plastic opening tool between the silver back plate and the screen. From the corner of the device on either side, pry the seam of the device about 1 inch.
    • With the plastic opening tool, pry the screen apart from the back plate.
    • Keep prying the screen apart from the back plate until they are separated.
    • With the plastic opening tool, if necessary, pry apart the remaining seams of the device.
    • After the screen is loose, pull the screen towards you. Lift it to prevent damage to the buttons.
  3. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 3, 3 resimden 1. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 3, 3 resimden 2. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 3, 3 resimden 3.
    • Locate the 3 black clips on the motherboard that hold the data cables./
    • Using the Spudger, pry the black clips up to a 90 degree angle./
    • Pull the data cables out once the clips are up to a 90 degree angle.
    • Repeat this for all 3 clips.
  4. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 4, 3 resimden 1. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 4, 3 resimden 2. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 4, 3 resimden 3.
    • Locate the two 4.0 mm Phillips head screws that are holding the motherboard in place.
    • Use the Phillips #00 screwdriver to remove both of the screws.
  5. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 5, 3 resimden 1. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 5, 3 resimden 2. Digitac Jazz Ultratab C725 Charging Port Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • The motherboard should now be loose.
    • To gain access to the charging port, flip the motherboard over.
    • Use the tweezers to pull the charging port off of the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Savannah Brazzeal
300 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-6, Blackwell Winter 2015 USF Tampa, Team 11-6, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G6
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 472
